As-Build Report Veeam - Guide for an easy installation
MarcoLuvisi
Hi All,
I can share my As-Build Report Veeam guide for an easy installation and a good results 😁 !
Sources:
https://github.com/AsBuiltReport/AsBuiltReport.Veeam.VBR
PS> $env:PSModulePath
Attending result:
Configure report options for use with -Verbose option to Allows you to set the technical parameters of the report, such as the type of data collected:
Enjoy Veeam reports !
47 comments
marcofabbri
  • 990 comments
  • August 31, 2023
Nice one Marco! :)
  • 8512 comments
  • August 31, 2023
I really like using these reports and have been since they came out.  Thanks for sharing this. 👍
jcolonfzenpr
  • 65 comments
  • October 18, 2023
Thank you for the content. I will be adding these recommendations to make it easier to use the report. I am working on a GUI made in C# for the AsBuiltReport.Veeam.VBR project that allows to generate these reports in an easier way.
Additionally I have been working on improving the report content and also adding support for drawing VEEAM B&R infrastructure diagrams.
Stay tuned...
  • 8512 comments
  • October 18, 2023
Stay tuned...
The diagram piece will be awesome 👍
Looking forward to that being added.
MarcoLuvisi
  • 275 comments
  • October 18, 2023
Stay tuned...
WOW !
Very usefull !!!
We wait impatiently !!!
CarySun
  • 200 comments
  • October 19, 2023
Stay tuned...
This is so cool! I can not wait to try it. Nice job @jcolonfzenpr @MarcoLuvisi
  • February 19, 2024
Hi All.
Great tool but how can I manage with multiple proxies in workgroup ? Each time ASBuild try to connect to the proxy I have an error saying :
VMware Backup Proxies Hardware/Software Inventory: Unable to connect to ...
VMware Backup Proxies Services Status Section: Unable to connect to ….
Thanks for your help
Regards
MarcoLuvisi
  • 275 comments
  • February 19, 2024
BROUSSEY wrote:
Hi All.
Regards
What do you means with “proxies in workgroup” ?
You mean that each proxy has different access credentials?
  • February 19, 2024
MarcoLuvisi wrote:
BROUSSEY wrote:
Hi All.
Regards
Each proxy is in a workgroup not in an ActiveDirectory so yes different access credentials.
MarcoLuvisi
  • 275 comments
  • February 19, 2024
BROUSSEY wrote:
MarcoLuvisi wrote:
BROUSSEY wrote:
Hi All.
Regards
@BROUSSEY do you execute PS under Veeam Power Shell console ?
  • February 19, 2024
MarcoLuvisi wrote:
BROUSSEY wrote:
MarcoLuvisi wrote:
BROUSSEY wrote:
Hi All.
Regards
Much better. Thanks a lot 😋
Mahmood.Alganadi
Stay tuned...
Hi @jcolonfzenpr
It is really impressive. Did you finish the tools I can’t wait to try it.
Thanks
jcolonfzenpr
  • 65 comments
  • February 19, 2024
The tool is Veeam.Diagrammer and it source code is located here:
https://github.com/rebelinux/Veeam.Diagrammer
From version 0.8.3 onwards the AsBuiltReport.Veeam.VBR report can generate diagrams if the "EnableDiagrams" option is set to true.
There is still a lot of work to be done to generate a complete infrastructure diagram. But for now there are several diagrams type that can be generated. I am interested in adding support for Cloud Connect but the license I was using for this purpose expired :(
Stay tuned...
Mahmood.Alganadi
I tried to generate the report by following all the steps in the above article also I downloaded all the module required but still stuck in below error
New-AsBuiltReport : The term 'Document' is not recognized as the name of a cmdlet, function, script file, or operable
program. Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
At line:1 char:1
+ New-AsBuiltReport -Report Veeam.VBR -Target 172.17.2.180 -Username 17 ...
    + CategoryInfo          : NotSpecified: (:) [Write-Error], WriteErrorException
    + FullyQualifiedErrorId : Microsoft.PowerShell.Commands.WriteErrorException,New-AsBuiltReport
I tried to troubleshoot and check lot of sites but still no luck, so what I am missing ?
  • 8512 comments
  • February 20, 2024
Mahmood.Alganadi wrote:
At line:1 char:1
Based on the error your syntax seems incorrect.  Check the examples above in the OP and model your commands from there.  I have done the same thing many times and need to remind myself to put the syntax in the proper format.
Mahmood.Alganadi
This is the command that I used and I double check with the article
New-AsBuiltReport -Report Veeam.VBR -Target 172.17.2.180 -Username 172.17.2.180\administrator -Password P@ssw0rd -Format Html,Word -OutputFolderPath ‘C:\VeeamReports’ -ReportConfigFilePath C:\VeeamReports\CustomReportConf.json -Verbose
Could you please chek?
  • 8512 comments
  • February 20, 2024
Based on this it looks correct from the example above.  Is there a space with the dash and password command?  I know web formatting is funky some times LOL
Example -
Based on this everything looks right even the single quotes.  Maybe @jcolonfzenpr can address this.
Mahmood.Alganadi
As I told you I copied the example command and changed only the red parts thats why I am sure that it is the same. I spent more than 3 hours to figure it out but with no luck even I restarted the process from the beginning step by step also without luck.
  • 8512 comments
  • February 20, 2024
Sounds good.  Hopefully the OP will reply when he has time.
Mahmood.Alganadi
I fixed the first issue it was a missing module called PScribo and I passed tthat issue but now stuck in another one which is :
New-AsBuiltReport : The 'Invoke-AsBuiltReport.Veeam.VBR' command was found in the module 'AsBuiltReport.Veeam.VBR',
but the module could not be loaded. For more information, run 'Import-Module AsBuiltReport.Veeam.VBR'.
At line:1 char:1
When I checked and did an import command it says that PSGraph issue as below :
PS C:\Users\Administrator> Import-Module AsBuiltReport.Veeam.VBR
Import-Module : The required module 'PSGraph' is not loaded. Load the module or remove the module from
'RequiredModules' in the file
'C:\Users\Administrator\Documents\WindowsPowerShell\Modules\Veeam.Diagrammer\Veeam.Diagrammer.psd1'.
At line:1 char:1
+ Import-Module AsBuiltReport.Veeam.VBR
    + CategoryInfo          : ResourceUnavailable: (C:\Users\Admini...Diagrammer.psd1:String) [Import-Module], Missing
   MemberException
    + FullyQualifiedErrorId : Modules_InvalidManifest,Microsoft.PowerShell.Commands.ImportModuleCommand
The module is exist but am not sure where is the problem exactly now as the diagrammer also there too
Any help in here coz my mind will blow :(
  • 8512 comments
  • February 20, 2024
At line:1 char:1
At line:1 char:1
   MemberException
I would suggest you go through the website and install all the pre-requisites needed for this to run properly. Sounds like something is still missing based on the errors.
Mahmood.Alganadi
Hi @Chris.Childerhose  Finally I figured it out and fixed it. It seems the offline Module from Github not working fine with me so I installed from PSGallery repo from another device (coz server that I worked on does not have internet access) and I loaded the new one and it works fine.
Thanks for you following up.
  • 8512 comments
  • February 21, 2024
Awesome that is great to hear you figured it out.  Glad to help. 👍
jcolonfzenpr
  • 65 comments
  • February 21, 2024
I'm glad you were able to resolve it and my thanks to those who helped you do so.
I have included the URL for the most recent instructions on how to run the report. In the future I will try to make the process for generating the report simpler.
https://techmyth.blog/posts/homelab-veeam-vbr-doc-with-asbuiltreport/
CDoerrenberg
I’m using a Rental license on a Veeam Server. The license typ is Enterprise plus.
While running the report I got the following message:
“New-AsBuiltReport : Current license does not allow this operation”
Is there a way to get rid of these error?
Regards
Christopher
