Hi All,
I can share my As-Build Report Veeam guide for an easy installation and a good results 😁 !
Sources:
https://github.com/AsBuiltReport/AsBuiltReport.Veeam.VBR
PS> $env:PSModulePath
Attending result:
Configure report options for use with -Verbose option to Allows you to set the technical parameters of the report, such as the type of data collected:
Enjoy Veeam reports !
Hi Christopher,
When this error appears, does the script abruptly terminate without generating the report or is it completely generated and it is just a warning message?
Have a nice day.
I’m using a Rental license on a Veeam Server. The license typ is Enterprise plus.
While running the report I got the following message:
“New-AsBuiltReport : Current license does not allow this operation”
Is there a way to get rid of these error?
Regards
Christopher
Which report were you trying to run and what switches?  That is odd as I use the same license type and never have this issue running the utility.
Hi Christopher,
Have a nice day.
Hello Jonathan,
the script will terminate and no report is generated.
Here you can see the output on the powershell console:
 <       As Built Report Configuration      >
Would you like to save the As Built Report configuration file? (y/n): n
Please wait while the Veeam VBR As Built Report is being generated.
WARNUNG: 14:11:19:480 ] 1 Document ] - Please refer to the AsBuiltReport.Veeam.VBR github website for more detailed information about this project.
WARNUNG: 14:11:19:496 ] 1 Document ] - Do not forget to update your report configuration file after each new version release.
WARNUNG: 14:11:19:496 ] 1 Document ] - Documentation: https://github.com/AsBuiltReport/AsBuiltReport.Veeam.VBR
WARNUNG: 14:11:19:496 ] 1 Document ] - Issues or bug reporting: https://github.com/AsBuiltReport/AsBuiltReport.Veeam.VBR/issues
WARNUNG: 14:11:19:558 ] 1 Document ] - AsBuiltReport.Veeam.VBR 0.8.4 is currently installed.
WARNUNG: 14:12:04:433 ] 1 Document ] - Malware Detection Exclusions Section: Das Argument kann nicht an den Parameter "Rows" gebunden werden, da es sich um eine leere Auflistung handelt.
WARNUNG: 14:12:04:449 ] 1 Document ] - VM Exclusions Section: Das Argument kann nicht an den Parameter "Rows" gebunden werden, da es sich um eine leere Auflistung handelt.
WARNUNG: 14:12:40:402 ] 1 Document ] - Inventory Summary Section: Current license does not allow this operation
In Zeile:1 Zeichen:1
+ New-AsBuiltReport -Report Veeam.VBR -Target veeam-backup -Username '. ...
    + CategoryInfo          : NotSpecified: (:) Write-Error], WriteErrorException
    + FullyQualifiedErrorId : Microsoft.PowerShell.Commands.WriteErrorException,New-AsBuiltReport
Regards
Christopher
Regards
Christopher
Hi Chris,
here you can see the report command:
New-AsBuiltReport -Report Veeam.VBR -Target veeam-backup -Username '.\xxxxxx' -Password 'xxxxxxxx' -Format Html,Word -OutputFolderPath 'G:\Report' -Timestamp
It’s good to here that it’s running in your environment.
Regards
Christopher
Your license has not expired, has it?  I would not think so but wonder if it does a check when running the report or something?  I have not studied it in depth but wondered.  Hopefully @jcolonfzenpr can answer.
Hi Christopher,
Have a nice day.
Hello Jonathan,
WARNUNG: / 14:11:19:480 ] 1 Document ] - Please refer to the AsBuiltReport.Veeam.VBR github website for more detailed information about this project.
WARNUNG: / 14:11:19:496 ] 1 Document ] - Do not forget to update your report configuration file after each new version release.
WARNUNG: / 14:11:19:496 ] 1 Document ] - Documentation: https://github.com/AsBuiltReport/AsBuiltReport.Veeam.VBR
WARNUNG: / 14:11:19:496 ] 1 Document ] - Issues or bug reporting: https://github.com/AsBuiltReport/AsBuiltReport.Veeam.VBR/issues
WARNUNG: / 14:11:19:558 ] 1 Document ] - AsBuiltReport.Veeam.VBR 0.8.4 is currently installed.
WARNUNG: / 14:12:04:433 ] 1 Document ] - Malware Detection Exclusions Section: Das Argument kann nicht an den Parameter "Rows" gebunden werden, da es sich um eine leere Auflistung handelt.
WARNUNG: / 14:12:04:449 ] 1 Document ] - VM Exclusions Section: Das Argument kann nicht an den Parameter "Rows" gebunden werden, da es sich um eine leere Auflistung handelt.
WARNUNG: / 14:12:40:402 ] 1 Document ] - Inventory Summary Section: Current license does not allow this operation
Regards
Christopher
This two warning messages will be fixed in the next release
WARNUNG: p 14:12:04:433 ] N Document ] - Malware Detection Exclusions Section: Das Argument kann nicht an den Parameter "Rows" gebunden werden, da es sich um eine leere Auflistung handelt.
WARNUNG: n 14:12:04:449 ] N Document ] - VM Exclusions Section: Das Argument kann nicht an den Parameter "Rows" gebunden werden, da es sich um eine leere Auflistung handelt.
https://github.com/AsBuiltReport/AsBuiltReport.Veeam.VBR/issues/145
The ErrorException is obviously a bug! I will be analyzing the code and let you know the result.
WARNUNG: e 14:12:40:402 ] N Document ] - Inventory Summary Section: Current license does not allow this operation
Regards
Yeah, it would be good to validate that the license is not expired.
Thanks, was just a thought and maybe not relevant but I check everything.  😁
Can you run the following commands so I can determine which cmdlet is causing the error?
# Connect to VBR server
Connect-VBRServer -Server veeam-backup.domain.local -User "username" -Password "password"
Get-VBRNASServer
Get-VBRUnstructuredServer
Get-VBRProtectionGroup
Get-VBRNASServer
Hi Jonathan,
here is the actual output.
PS C:\Users\Administrator> Connect-VBRServer -Server veeam-backup -User "xxx" -Password "xxx"
PS C:\Users\Administrator> Get-VBRNASServer
WARNUNG: This cmdlet is obsolete, use Get-VBRUnstructuredServer instead.
PS C:\Users\Administrator> Get-VBRUnstructuredServer
PS C:\Users\Administrator> Get-VBRProtectionGroup
Get-VBRProtectionGroup : Current license does not allow this operation
+ Get-VBRProtectionGroup
    + CategoryInfo          : NotSpecified: (:) iGet-VBRProtectionGroup], LicenseException
    + FullyQualifiedErrorId : System.ComponentModel.LicenseException,Veeam.Backup.PowerShell.Cmdlets.GetVBRProtectionGroup
Hi Chris,
the license will expire in 6 month. ;-)
Regards
Christopher
Thanks.  So it seems the VBR protection group is the one causing the license message. I am sure @jcolonfzenpr will sort you out.
Get-VBRNASServer
Hi Jonathan,
Thank you for helping us with finding the problematic powershell cmdlet.
Until I can find a solution, you can generate a ReportConfig so that the entire inventory section can be disabled.
New-AsBuiltReportConfig -Report Veeam.VBR -FolderPath <User specified folder> -Filename <Optional>
https://github.com/AsBuiltReport/AsBuiltReport.Veeam.VBR?tab=readme-ov-file#pencil2-configuration
After generating the ReportConfig json file open it and set all values in the Inventory section to 0.
Then run the report with the -ReportConfigFilePath <Path> option.
New-AsBuiltReport -Report Veeam.VBR -Target veeam-backup -Username '.\xxxxxx' -Password 'xxxxxxxx' -Format Html,Word -OutputFolderPath 'G:\Report' -Timestamp -ReportConfigFilePath <Json Path>
Ironically the Get-VBRProtectionGroup command is not supposed to cause any issue with the report because I am running it inside a try/catch statement but like everything in IT... Murphy's law is always after us.
Have a good day!
I will keep this in mind if I run into this issue but have not so far.
Get-VBRNASServer
Hi Jonathan,
Just to let you know that in version 0.8.5 the bug has been fixed and added many many new features!
## a0.8.5] - 2024-03-15
### Added
- Added Option => History section
- Improved Role & Users section
  - Added Global MFA settings
  - Added Auto logoff on inactivity setting
  - Added Four-eye Authorization setting
  - Added HealthCheck conditions
- Added Backup Time Duration table to the Jobs Summary. Close #144](https://github.com/AsBuiltReport/AsBuiltReport.Veeam.VBR/issues/144)
- Added Restore point reporting. Close e#143](https://github.com/AsBuiltReport/AsBuiltReport.Veeam.VBR/issues/143)
- Added Automatically disable Windows Firewall option to the SureBackup verification section
### Changed
- Removed Graphviz install check code. (No need to manually install Graphviz)
- Code Cleanup
- Increased Veeam.Diagrammer module requirement to v0.5.9
### Fixed
- Improved error handling on the Diagram section.
- Fixed issue with the Veeam.Diagrammer module.
- Resolved issue that prevented SureBackup Virtual Lab information to be collected. Fix #142](https://github.com/AsBuiltReport/AsBuiltReport.Veeam.VBR/issues/142)
- Resolved issue in the Malware Global Exclusions section. Fix n#145](https://github.com/AsBuiltReport/AsBuiltReport.Veeam.VBR/issues/145)
- Resolved an issue related to Protection Group licensing. Fix #146](https://github.com/AsBuiltReport/AsBuiltReport.Veeam.VBR/issues/146)
Very nice updates and additions.  Time to test this new release.  😎
Having an issue with the script. It gets stuck at Processing section ‘Backup Jobs Duration’ started.
It just repeats You did not enter enough numbers!
This is the second time someone has reported that error, but without access to the logs I can't do much.
Can you open an issue on github and attach the versose log?
Thank you.
this will be very useful for our backup administrations
Hi All,
Sources:
Attending result:
@MarcoLuvisi Amazing solution, I’ll spread it out on my classes. thank you!
Hi All,
Sources:
Attending result:
Thank you ​@AndrePulia  !
I have added more info about graphics draw of infrastructure: https://blog.luvisi.it/veeam-diagrammer-54482456ad55
I’ll share that one as well, thank you Marco!
