Hello Veeam community!
I hope everyone is doing well. I'm reaching out to this amazing community because I'm in need of some guidance related to configuring a DAS (Direct-Attached Storage) drive in my Veeam Backup setup.
Background:
I've been utilizing Veeam Backup for a while now, and it's been a lifesaver in terms of managing my backups efficiently. However, I'm now faced with the task of incorporating a DAS drive into my backup infrastructure. This is a new territory for me, and I want to ensure that I'm setting it up correctly to maximize its potential.
How do I go about adding a DAS drive to my existing Veeam Backup setup?
Are there any specific best practices or considerations I should keep in mind when configuring a DAS drive in Veeam?
What kind of performance improvements can I expect by using a DAS drive, and how can I measure these improvements effectively?
I've always found that this community is extremely knowledgeable and helpful when it comes to troubleshooting and sharing insights. I believe that your collective expertise can provide valuable insights into configuring a DAS drive effectively within the Veeam ecosystem.
I would greatly appreciate any guidance, tips, or personal experiences you can share regarding using DAS drives with Veeam Backup. If you have any step-by-step instructions or screenshots to assist in the setup process, that would be fantastic.
Thank you all in advance for your help and contributions! Your support is what makes this community so great.
Best regards,
Yamaris
