Veeam erstellt Snapshot und lässt sich nicht entfernen oder in Hyper-v auftauchen
  • July 18, 2024
  • 1489 views
Hello everyone,
Veeam automatically creates snapshots and they do not appear in Hyper-v console.
I tried removing or merging them but it doesn't work.
Is there a Powershell command for this? or how to remove manually?
Hallo zusammen,
Veeam erstellt automatisch Snapshots und sie taucht nicht in Hyper-v console.
Ich habe es versucht sie zu entfernen oder Zusammenführen aber klappt es nicht.
Gibt es Powershell Befehl dazu ? oder wie kann man manuell entfernen ?
  • July 18, 2024
Hi @Madi.Cristil @safiya  can you please move this post to the Discussions group? Thank you.
Hi @Aldiere -
Can you please provide more info? What VBR version are you using? Are you using the Virtual Appliance (hotadd) transport mode? Are you saying Veeam is not removing the snapshots from VMs when backing them up? Or is there something else you're asking?
lukas.k
  • July 22, 2024
Hi @Aldiere,
It is normal that Veeam creates Hyper-V snapshots for VM backups and totally expected. Please keep in mind that the snapshot will be hold until the current backup task is completed - same is for replication task in case you are using some.
There might sometimes be some snapshots that cannot be removed or merged by Veeam, I saw that multiple times. You have to login to the relating Hyper-V server and use the following PowerShell command:
Remove-VMSnapshot -VMName XXX -Name XXX (This removes the snapshot with a specific name, -Name is related to the Snapshot name)
Remove-VMSnapshot -VMName XXX * (This removes all snapshots for a specific VM)
Again - please check that no Veeam job is currently running that is using one of the snapshots to be deleted.
Have fun!
Best regards
Lukas
