VM Conversion using Instant Recovery
  • September 21, 2025
  • 10 comments
  • 407 views
hs08
I try to migrate my vmware VM to hyper-v using veeam and i always got ‘failed to modify disks”. Anyone know how to fix this?
Seems there are many posts on the forums about this and Linux OS.  Check this one but there are many more with a Google search - https://forums.veeam.com/veeam-backup-replication-f2/failed-to-modify-disks-when-doing-an-instant-restore-to-hyperv-t77368.html
hs08
  • September 22, 2025
@Chris.Childerhose
For another linux VM yes i can successfull migrate to hyper-v using same method. Only for this one VM the migration is failed.
@Chris.Childerhose
Then I would suggest contacting support for assistance.
hs08
yes, i already open ticket to veeam support. WIll post here about the solution if the issue was resolved.
https://www.veeam.com/blog/vmware-to-hyper-v-migration.html
https://en.ittrip.xyz/windows/troubleshooting/linux-hyperv-veeam
this article may help you
dips
What have you tried so far?
MarkBoothman
When you edit the VM the disk size doesn’t show something more than 2 decimal places does it
for example
100.00224443433434 GB
Sounds good let us know how things go and the solution.
  • November 21, 2025
Hi, I have the same issue. Did support come up with solution? Thanks!
