I am new to Veeam, so I apologise if this is a stupid question.
I have a number of remote sites that each have a Proxmox server. Each of these servers is connected to my home using a TailScale network. There is a Linux VM acting as a subnet router.
I am trying to use the latest version 12.3 of Veeam to backup the VM’s on the remote sites to a small NAS installed in each site. Basically, I want to manage the backups from a central location, but the backups actually take place at the remote sites.
I can register the remote Proxmox servers centrally, but when I run the test on the worker created at each site, it looks like it will run OK; it starts the worker, connects to it, but then always fails on the connect to core services, and occasionally fails on failed to obtain IP address.
As a test, I have disabled the firewall on the central backup server and the worker VM. But the errors are the same.
I have tested the connection between sites using several other applications, and it works well and is stable.
My questions are:
Is it possible to achieve what I want: central management of remote Proxmox servers?
Is there anything special I must do to make it work across Tailscale networks with subnet routers?
Has anyone made this work? If so, how did you do it?
Many thanks in advance for any help you can provide.
How to use Veeam for Proxmox for remote sites using Tailscale.
