What Automation tools are you using?
mkevenaar
Forum|alt.badge.img+15
Hi All,
I wonder, what kind of tools are you using for your day-to-day automation tasks?
My top / most used list:
  • Chocolatey
  • Boxstarter
  • PowerShell
  • Ansible
  • Bash
15 comments
Forum|alt.badge.img+17
  • 2650 comments
  • October 17, 2022
At the moment mostly:
  • Powershellscripts
  • Batch scripts
  • 8502 comments
  • October 17, 2022
The main ones I use at the moment -
  • Chocolatey
  • PowerShell
  • Terraform
Geoff Burke
  • 1318 comments
  • October 17, 2022
  • Ansible
  • bash
  • PowerShell
  • Chocolatey
BertrandFR
  • 528 comments
  • October 17, 2022
Ansible, Terraform, Rundeck.
dloseke
  • 1447 comments
  • October 17, 2022
Pretty much just PowerShell for me, but I’m a bit of an automation newbie, so I’m open to options!  Whatever tool works best for the task at hand.
StefanZi
  • 49 comments
  • October 18, 2022
  • Ansible
  • PowerShell
  • Bash
  • Terraform
  • Gitlab-CI
I wonder if you can classify Chocolatey as automation tool …. nobody said apt, yum or zypper :D Though I am using chocolatey, too ;-)
SteveHeart
  • 75 comments
  • October 19, 2022
I use Veeam Backup & Replication - It automagically starts jobs and is also able to trigger my Powershell scripts 🤣
Joking apart, I’m using Powershell and simple batch scripts and on Linux the good old bash. I don’t know if we can count AWS Cloudformation to it, but it also helps to setup testing environments.
mkevenaar
  • 149 comments
  • October 19, 2022
Whaha, yes VBR does some stuff automagically as well 🤣
CloudFormation is a method of deploying AWS environments, Infrastructure as Code. I would say YES that counts automation as well!
k00laidIT
  • 73 comments
  • October 19, 2022
Honestly most of what I use these days is powershell by way of VS Code. I also use the various swagger docs for Veeam products as well to help guide my calls and test capabilities. Enough that I keep them all as a pinned tweet!
https://twitter.com/k00laidIT/status/1364586142025322499?s=20&t=vDeDsTvPY_G3ZfsOiPBcCA
JHoughes
  • 19 comments
  • October 26, 2022
The list has gotten longer…
PowerShell, Ansible, Terraform, Bash, GitHub Actions, Gitlab, Circle CI, ArgoCD
And getting back into Python after a few years.
alexheylin
  • 5 comments
  • November 4, 2022
  • MySQL / PHP (yes really! - I can do ALL the things by interacting with our RMM DB 😉)
  • C#
  • PowerShell
vNote42
  • 1246 comments
  • November 10, 2022
PowerShell is my top. Try to use more vSphere Operations.
Nico Losschaert
  • 681 comments
  • November 12, 2022
Powershell is the only being used, too less at the moment...
  • 10 comments
  • January 18, 2023
  • Powershell
  • Ansible
  • Python
  • Bash
vAdmin
  • 168 comments
  • January 31, 2023
I’ve been using PowerShell so far.
