Veeam Validator Script for VBR v13: Advanced Backup Validation Automation
  • Apr 21, 2026 2:31 PM UTC
  • 249 views
With the release of Veeam Backup & Replication v13, backup validation has become even more critical—especially in enterprise environments where data integrity and compliance are non-negotiable. In this context, Veeam-Validator emerges as a practical solution to extend and automate the native Veeam validation capabilities.
Download script:
L1nkState/Veeam-Validator-: Veeam Backup Validator A PowerShell automation script to validate Veeam backups and optionally send HTML reports via email. Designed for Veeam Backup & Replication v12 and v13, schedulable via Windows Task Scheduler.
What is Veeam Backup Validator (Technical Context)
The native Veeam Backup Validator is a CLI utility designed to verify backup file integrity without performing a restore. It works by leveraging block-level checksums: during backup creation, hashes are generated for each data block, and later recalculated and compared to detect corruption.
From an operational standpoint:
  • Works at file-level (CRC checks)
  • Does not boot VMs (unlike SureBackup)
  • Generates HTML/XML reports
  • Requires administrative privileges
This makes it a lightweight and efficient tool for post-operation checks, audits, and storage validation.
Limitations of the Native Validator
Despite its reliability, the native tool has several operational constraints:
  • Not designed for complex automation
  • Requires manual execution or custom scripting
  • Limited orchestration across multiple jobs
  • Constraints with advanced repositories (e.g., Cloud Connect, SOBR scenarios)
The Veeam-Validator Project on GitHub
The Veeam-Validator repository aims to modernize the validator CLI by making it more automation-friendly and easier to integrate into operational workflows.
Core Objectives
The script is designed to:
  • Automate validator execution
  • Standardize integrity checks
  • Improve logging and reporting
  • Enable integration into scheduled or DevOps pipelines
In essence, it acts as an intelligent wrapper around Veeam.Backup.Validator.exe.
Architecture and How It Works
From a technical perspective, the script:
  1. Invokes the native validator
    • Uses standard CLI parameters (backup, VM, report)
  2. Implements execution logic
    • Iterates across multiple backups/jobs
    • Handles errors and retry mechanisms
  3. Produces structured outputs
    • Readable logs
    • Centralized reports
  4. Adds additional control layers
    • Pre/post validation checks
    • Potential integration with monitoring systems
This aligns with other Veeam automation initiatives, such as security and compliance analysis tooling.
Relevance with VBR v13
With version 13, Veeam has strengthened its validation ecosystem and raised standards for verification processes. As a result, tools like Veeam-Validator become increasingly valuable for:
  • Continuous backup validation
  • Post-upgrade verification workflows
  • Infrastructure compliance checks
  • Reducing the risk of undetected backup corruption
Practical Use Cases
1. Scheduled Validation
Automate daily or weekly validation for critical repositories.
2. Post-Storage Migration Checks
Ensure data integrity after moving backups between storage tiers or locations.
3. Audit and Compliance
Automatically generate validation reports for internal or regulatory audits.
Operational Best Practices
To maximize effectiveness:
  • Run with administrative privileges (no MFA constraints)
  • Schedule execution outside backup windows
  • Integrate with alerting systems (email, SIEM, monitoring tools)
  • Do not replace SureBackup entirely (which validates application bootability)
Final Considerations
The Veeam-Validator project does not introduce a new validation mechanism—it enhances the usability and operational integration of the existing one.
In VBR v13 environments, where resilience and security are critical, this approach enables a shift from occasional checks to a continuous validation model, significantly reducing operational risk.
Great little script Link State.  I will give it a test and provide some feedback. 😎
