[PowerShell, PowerCLI] Check for VMs that are not being backuped
  • Nov 4, 2020 8:03 PM UTC
  • 38 comments
  • 5225 views
Show first post
38 comments
vNote42
  • Nov 4, 2021 3:42 PM UTC
just a regular vmdk backup.
thank for looking into this.
I would run the command Get-VBRRestorePoint to see if the restore point is reported.
  • Nov 4, 2021 4:01 PM UTC
no results on it , interesting
I get results on other Systems but not this one
What is that mean exactly ?
regnor
  • Nov 4, 2021 7:09 PM UTC
Does this VM have a parent backup job or is it an imported backup? Just a guess from my side, but Get-VBRRestorePoint could possibly only show restorepoints for existing jobs.
vNote42
  • Nov 4, 2021 8:07 PM UTC
Could it be, you changed the name of the VM in the last 1024 days? But also the VM-name is not correct in your query:
  • Nov 4, 2021 9:18 PM UTC
that is just a addition to the name we add in Vsphere , if I try to use that in a query.
The only thing that might have changed would be restore from backup but can’t say for sure.
vNote42
  • Nov 4, 2021 9:20 PM UTC
you forgot quotes: Get-VBRRestorePoint -Name “STVP-UT11 Print Server”
  • Nov 4, 2021 9:43 PM UTC
good point
That shows restore points from the query.
Those backups are too old for us to be used anyway, I think what I will do is to purge them and set up new one for that box. I don’t see any other servers with this problem.
I realize this might be off topic but is there a script that would get us output of restore points older than x years and purge ones older than specified date or is it all based on configured retention only?
vNote42
  • Nov 4, 2021 9:54 PM UTC
You are right. You have to ask yourself if it is a good idea to define a VM as backed up when the newest restore point is 3 years old. You can add some logic to the script to calculate the age of a each restore point. Then you have to decide how old a restore point can be to take a VM as currently backed up.
  • Nov 4, 2021 10:27 PM UTC
I was hoping that Veeam Legend would be kind enough to help us out with that :)
  • Sep 16, 2022 6:03 PM UTC
Been a while but does anyone know how to pick up only VM’s that’s not backed up past day??
The script works great and I have added the email portion to it so we get a nice HTML bodied email with all the VM’s not backing up.
I need this to work on VM’s not backed up past day, any ideas??
Thanks in advanced.
vNote42
  • Sep 22, 2022 12:20 PM UTC
Thanks in advanced.
Hi Tom!
Its not that hard to do so. You need to filter retrieved backups by adding an additional filter in the line: $VbrRestore = Get-VBRBackup | Where-Object … to get just backups of the date range you want to have. At the moment I do not have any lab, therefore I cannot post the correct command for that. Please let me know, If you need further help.
  • Mar 29, 2023 9:59 AM UTC
# Read Credential-File
$WorkingDir = "C:\_install\script\"
$CredObject = Import-Clixml -Path ($WorkingDir + "CredObject.xml")
Hello!
Could you help me, what Credential-File should I provide?
Hello!
You need to provide the CredObject.xml as noted in the code block above and in the directory noted.
