Need help to prepare for VMCE_v12 exam
I am preparinf for my VMCE_v12 exam and i am seeking best exam preparation resource. Are there any practice test i can access to prepare for my exam?
Best answer by MicoolPaul
Hi, the best exam prep for the VMCE is trying the different features in a lab/your environment, and reading the Veeam documentation. None of the questions are designed to trick you and are more focused on your understanding of concepts than explicit details.
I believe the Veeam partner portal has some mock exams if you’re a partner. I’d also suggest trying the Veeam hands on labs 🙂
kristofpoppe
Hi @lynnhall , there are several test-exams available. Definitly have a look at Rasmus Haslund’s site.
https://rasmushaslund.com/vmce-practice-exam/
Also the blog of Hammond Rhys has a lot of info.
https://rhyshammond.com/vmce-material/vmce-2021-practice-exam-pool/
When you have access to the Veeam Propartner Portal, there is a test-quiz available.
tarik.yenisey
Yes, its true. Me too will start practice coming soon for VMCE :)
Aside from the suggestions already offered, there is a VMCE page here on the Community Hub with study suggestions & practice questions as well.
https://community.veeam.com/groups/vmce-study-hall-134
Lots of resources as others have said but nothing beats hands on with the product to learn and reinforce concepts for the exam.  Best of luck with your studies.
