How Veeam will help achieve Technical prowess in Kafka,Docker,Websub,PostgreSQL,Kubernetes,Kibana
  • October 15, 2022
  • 202 views
RK99
Shed somelight on how Veeam will help Kafka,Docker,Websub,PostgreSQL,Kubernetes,Kibana
Best answer by regnor
From the applications you mentioned, Veeam does only support PostgreSQL and Kubernetes. Perhaps you can describe in more detail what your trying to achieve.
Application consistent backup of PostegreSQL at the moment is only possible with Veeam Agent for Linux. With the next release, v12, PostegreSQL will also be supported with VM backups.
Kubernetes backups can be performed with Kasten K10.
regnor
  • October 16, 2022
