Facing problem with the Veeam Calculator
  • Sep 24, 2025 5:54 PM UTC
  • 9 comments
  • 83 views
AndrePulia
Hi Community,
Does anyone knows if the calculator is under maintenance for CPD replication?
I’m getting the error below.
Best answer by david.tosoff
Hi ​@AndrePulia is this still an issue?
I apologize for the late response. I cannot currently recreate this, but if its still an issue, let us know.
Cheers,
9 comments
  • Sep 24, 2025 6:20 PM UTC
I haven’t seen anything ​@AndrePulia . Hopefully one of the moderators of this Calculator Commons page can chime in to help you out (looks like Madi or Safiya moved your post already 🙂).
AndrePulia
  • Sep 24, 2025 6:28 PM UTC
Thank you Shane for that! :-)
  • Sep 24, 2025 6:29 PM UTC
Yes sir...sure thing. Sorry I didn’t have any definitive answer for you though.
SCZEPANSKI
  • Sep 25, 2025 11:48 AM UTC
Still with problem.
I believe it is under maintenance
AndrePulia
  • Oct 14, 2025 11:46 AM UTC
Hi Community, I still facing the same issue using the calculator, does anyone know what is happeing with it? I’ve tested it on different browsers and computers, some results.
Thank you all!
david.tosoff
  • Nov 14, 2025 11:16 PM UTC
Cheers,
waqasali
  • Nov 17, 2025 6:46 AM UTC
A few users have reported errors or non functionality when trying to use the calculator for CDP replication.
These issues seem to persist across different browsers. Try switching to the older version via the “Previous Versions” link on the calculator splash page.
For CDP-specific sizing, consider reaching out to Veeam support or your local SE for manual guidance until the issue is resolved.
david.tosoff
  • Nov 17, 2025 2:46 PM UTC
It is currently working, to my testing. Both the frontend and backend of the tool are “living” and in continuous improvement, so there are no previous versions to go back to. :)
AndrePulia
  • Nov 18, 2025 9:29 PM UTC
Cheers,
HI David,
JUst tested it! seens to be OK now. thank you David.
