Resources for someone starting at zero
  • May 19, 2025
  • 74 views
New to Veeam and its offerings, wanted to know if anyone can point me to some resources that I can read/use/reference for getting started with scripting with Veeam 12?
Best answer by mdean
I used the Veeam PowerShell reference to get used to the command structure and cmdlets and then went from there to write a few scripts like job status and stuff.
https://helpcenter.veeam.com/docs/backup/powershell/getting_started.html?ver=120
  • May 19, 2025
Also if you Google there is a ton of stuff out there for Veeam and PS.  Also we have scripting here on the community.
Marcel.K
  • May 20, 2025
i would suggest to use chatgpt to deploy scripts, if you know what you would like to achieve. If you has knowledge about scripting, then is easy way …
for inspiration i would suggest same as Chris, here in community, where you can ask as well to help you to fix the issues...
ratkinsonuk
  • May 20, 2025
There’s a huge repository of Powershell code you can copy at https://github.com/veeamhub
Claude.ai is another good one as well for scripting as I have used that one lately.
MarkBoothman
  • May 20, 2025
The forum has a dedicated section for PowerShell. They are a friendly bunch as well.
https://forums.veeam.com/powershell-f26/
