Get what backup jobs and tape jobs are running using PowerShell
  • February 13, 2026
  • 118 views
Support recommended restarting the service to improve high memory usage caused by Veeam.Backup.CatalogDataService.exe.
I would like to run PowerShell using Task Scheduler to periodically restart the service.
To prevent job errors, I would like to output backup jobs and tape jobs when the running service is restarted, but I don't know how to do this.
Get-VBRBackupSession | Where-Object {$_.Result -eq 'None'} seems to output running backup jobs, but I don't know how to output tape jobs.
Please tell me the following:
・ Is there a way to output appropriate running backup jobs other than those listed above?
(Get-VBRBackupSession -Name $job does not work because it does not output when differences are being merged.)
・ How can I output running tape jobs and GFS tape jobs?
Try this PS and see -
# Load Veeam snap-in
Add-PSSnapin VeeamPSSnapin -ErrorAction SilentlyContinue
# Running backup jobs
Get-VBRJob | Where-Object { $_.IsRunning } |
Select-Object Name, JobType, @{N="State";E={$_.GetLastState()}}
# Running tape jobs
Get-VBRTapeJob | Where-Object { $_.IsRunning } |
Select-Object Name, Type, @{N="State";E={$_.GetLastState()}}
  • February 13, 2026
# Running tape jobs
  • February 13, 2026
Good one Chris!
@kamo - if you need further guidance beyond what Chris shared...make sure to give the Veea PS Reference Guide a look too:
https://helpcenter.veeam.com/docs/vbr/powershell/tape_jobs.html?ver=13
  • February 16, 2026
ありがとうございます。試してみます
  • February 16, 2026
Thank you for your kind reply.
I tried running all the commands you instructed while the tape job was running, but nothing was output.
I'm using Veeam version 12.
I'm new to both Veeam and PowerShell, so I'd like some advice.
W
When I ran the commands without "Where-Object { $_.IsRunning } |", the State field was blank.
Is this related?
Get-VBRTapeJob |
The white areas indicate the names of tape jobs and my username.
  • February 16, 2026
$CHKT = $Get-VBRTapeJob | Where-Object { $_.LastState -eq "Working"}
I'm thinking of determining whether or not to restart the service based on whether or not the above command outputs anything, but could you please let me know any concerns you might have?
(For example, are there any statuses other than Working that shouldn't be restarted?)
  • February 16, 2026
Working or running would be the state of jobs.
