Dear All,
I have a special technical issue, due to Veeam B&R backup existing schedule setting cannot fill the need requirement, the backup targe include the vSphere and Veeam agent for Windows / Linux.
The backup requirements:
.1 The schedule daily job for Jan, Mar, May, Jul, Sep, Nov backup to NAS A.
.2 After schedule daily job for Feb, Apr, Jun, Aug, Oct, Dec backup to NAS B.
Existing backup schedule provide the basic daily, weekly and monthly only, how the customize backup schedule for special requirement???
Thanks.
How customize backup job issue - Veeam B&R
Well there is no way to skip months and have Veeam automatically switch repositories for you as that requires manual intervention unfortunately. You can use GFS for the monthly backup in the job but as I said it will require two jobs and disabling one after Jan for the Feb one to run on NAS B. There is not auto switching.
