SureBackup Configuration Problem
  • February 24, 2026
  • 105 views
NemanjaJanicic
Hi everyone,
I have a SureBackup issue and I’m trying to understand the IP selection behavior.
Setup
Repository server has two NICs:
Management NIC
  • 192.168.10.191
  • Has gateway
  • Domain profile
iSCSI NIC
  • 172.16.100.11
  • No gateway
  • No DNS
  • Used only for iSCSI to Synology
Problem
SureBackup fails with:
Failed to connect to the endpoint [172.16.100.11:2500]
Veeam is trying to connect to the iSCSI IP instead of the management IP.
What I verified
  • VBR can connect to 192.168.10.191:2500 → OK
  • VBR cannot reach 172.16.100.11 → expected
  • VeeamTransportSvc is running
  • Port 2500 is listening
  • Firewall rule for 2500 exists
  • iSCSI NIC has no gateway
  • Management NIC has lower metric
Windows DNS API returns
192.168.10.191
172.16.100.11
So management IP is first.
Best answer by NemanjaJanicic
I resolve the issue, thank’s ​@Link State  and ​@CMF  for reaching out to help.
At the end it was Firewall policies problem, the communication between VLANs were not properly configured.
CMF
  • February 24, 2026
Hi ​@NemanjaJanicic ,
Have you verified whether the hypervisor is able to connect to the repository? It uses the same mechanism as Instant Recovery, meaning the repository is mounted directly to the hypervisor so it can start the VMs from it.
Have you also checked your firewall to confirm which system is attempting to connect to this IP?
If you’re unable to identify the issue, it might be a good idea to open a support case.
  • February 24, 2026
Hi ​@NemanjaJanicic
Try configure on veeam server  “Preferred Networks”
  • Enter the subnet for your Management network (e.g., 192.168.10.0/24).
  • Ensure the checkbox "Allow backup traffic over these networks only" is checked if you want to strictly prevent it from ever touching the 172.x.x.x range.
  • Move this network to the top of the list.
Unregister DNS on NIC ISCSI
  • Right-click the iSCSI NIC > Properties > IPv4 > Advanced > DNS tab.
  • Uncheck "Register this connection's addresses in DNS".
Veeam sometimes caches the IP list for a managed server.
Right-click your Repository server > Properties.
In the Name field, ensure you are using the FQDN or the Management IP (192.168.10.191), not a generic NetBIOS name that might resolve inconsistently.
Click through the wizard to the end. This triggers a "Discovery" process that updates the IP list Veeam holds in its configuration database.
Set NIC Management to 10 and iSCSI to 500
NemanjaJanicic
  • February 24, 2026
Hi ​@NemanjaJanicic
Hey ​@Link State,
Already checked that before created this topic. Issue persist after those checks
  • February 24, 2026
Hi ​@NemanjaJanicic   Try adding a static route for the SCSCI network, assigning it the GW.
route add -p  192.168.10.xxx mask “your mask”     “Your GW ip”
NemanjaJanicic
  • February 24, 2026
CMF
  • February 24, 2026
Great news ​@NemanjaJanicic . Hope everything is working fine now.
Regards
Chalid
  • March 20, 2026
@NemanjaJanicic  - just wanted to follow up to see if you got an answer to your inquiry?  If so, please mark the best answer that helped the most, even if your own.  Look forward to assisting further if needed.
