Backup AWS Storage Gateway Volume Gateway EBS volumes using Veeam for AWS 8.0
  • January 10, 2025
  • 29 views
Hi Veeam community, is it possible to backup AWS Storage Gateway Volume Gateway EBS volumes using Veeam for AWS 8.0 or Veeam BR 12 or any Veeam product for that matter?
  • January 10, 2025
If the volumes sit on EC2 then you can.  Don't use AWS so maybe the help document will help answer this - https://helpcenter.veeam.com/docs/vbr_aws/deployment/using_vbr_in_aws.html?ver=120
  • January 10, 2025
This section has more on what it can back up - https://helpcenter.veeam.com/docs/vbaws/guide/welcome.html?ver=80
  • January 10, 2025
Thanks Chris. I am backing up EC2 instances at the moment but I’d also like to backup my Volume Gateway EBS volumes as well. If Veeam can’t do it my only option between Veeam and AWS is to use AWS Backup but I’d like to keep all of my backup data in Veeam if possible.
  • January 10, 2025
I can definitely understand that and hope you get an answer.  If I knew more about the AWS backup stuff I would try to help more.  Maybe time to start learning that and Azure. 😋
