Veeam Ports Calculator not showing correct ports for SQL restore
  • September 21, 2026
  • 17 views
I was noticing that the Veeam Ports Calculator is not showing the correct port ranges for SQL restores and the different SQL restores.
Same Database location, different database location, instant restore, publishing.
Same database restore does require iSCSI connection on port range 3260-3270, this is not showing up in the calculator.
tsmith
Ill check it out tomorrow. We have an update pushing soon with 13.1 changes so ill check that its in there
tsmith
  • September 23, 2026
I’ve confirmed this is in the updated version (which will be live soon) - showing the iscsi ports required from sql to the mount server.
