Veeam Calculator Sizing for proxy is extremely low
I have Two site, 340 Instance  with total 340TB at Site A and 160 Instance with 160 TB at Site B, use CDP replication as well. after i imported the rvtool report and the report show only 2 cores needed for proxy and 4 core for VBR, this didn't make sense at all
9 comments
  • 8502 comments
  • February 12, 2025
What happens to the specifications if you do the data entry manual?  I would enter the details manual just to compare and see if there is a difference.  Not sure why it would be that low.
  • 18 comments
  • February 12, 2025
enter manually is the same result, i first attempt is enter information manually, and the report result same as the proxy and VBR cores is very low. my second attempt is to import RVtools report and hope it work better but unfortunately it show up to 2 cores for the proxy only. i even try to remove the CDP and capacity tier, just to focus on local backup for single site 340 Instances, 100TB, Backup windows 8 Hours, GFS 14 Days, 16 Weeks, 12 Month and 7 Years. the result still the same it show only 4 core for vbr and 1 core for proxy.
  • 8502 comments
  • February 12, 2025
Does it show that it is an all-in-one VBR/Proxy server or are they separate?  Just asking as I have not used the calculators for a while.  Maybe ​@david.tosoff can assist here.
  • 18 comments
  • February 12, 2025
it show separate compute resources for VBR, Veeam DB, Veeam One, Veeam Enterprise,  proxy and repo server, but all with very little cores.
david.tosoff
  • 15 comments
  • February 12, 2025
Hi ​@kelvin koh,
The simplified math behind Veeam proxy sizing is this:
[Data] x [Change Rate] x / [Backup Window] (excluding growth and some other factors)
If you take your 100TB example:
100TB x 5% (I’ve assumed) / 8h = 5TB/8h = 0.625TB/h
= 182 MB/s
= 182/ 80 per core (virtual) rounds out to around 2C
Based on BP proxy sizing estimates here (https://bp.veeam.com/vbr/2_Design_Structures/D_Veeam_Components/D_backup_proxies/vmware_proxies.html#processing-resources)
Now, as far as your 340TB example only equating to 2 cores, that’ll need more specifics for the unknowns to validate: If the change rate you’re using is low then that could be why. Likewise if compression is tuned off of default, etc.
Here is 340TB @ 1% vs 5%:
1.55 core vs. 7.74 core
  • 18 comments
  • February 12, 2025
 my setup:
david.tosoff
  • 15 comments
  • February 12, 2025
 Hi Kelvin, as linked above, the throughput rates are what affect the core count in the proxy math.
You’re using physical proxy, so 250MB/s is the assumed per core throughput
If you factor out the math manually, you’ll arrive at ~2.18 cores as well. Without physical proxy, you’ll arrive around 6.8 cores.
  • 18 comments
  • February 13, 2025
if based on manual calculation 340 Instance with 160 TB we should need 32 cores proxy as per advise from principle.
  • 9 comments
  • February 13, 2025
Hi Kelvin,
If you don’t mind, could you please export your scenario as a file and share it so we can have exact details about what inputs are used?
Also, can you give an example of the manual math? I have presented the sizing courses at VeeamON the past several years and the processing rate used for manual formulas used to be 25 MB/s but now is variable based on the chart that ​@david.tosoff posted above. At minimum (80 MB/s), the proxy resources are reduced to approx. 33% of previous formulas. Best case (250MB/s) they are reduced to 1/10 of previous numbers. All of this based on extensive performance testing by our QA teams.
