Same Console, Same Repositories, Same Jobs, Different Hypervisor: Veeam 13.1 Meets Openshift Virtualization 🤓
  • Sep 14, 2026 10:43 AM UTC
  • 9 comments
  • 224 views
eprieto
Veeam 13.1 can back up OpenShift Virtualization VMs from the console your team already uses, without an agent in the guest. Here's the architecture in one diagram: five components, two of them new, and the five steps a backup job takes across them.
Components
VBR Server — the one giving orders
  • What it is: your existing Veeam Backup & Replication machine, physical or virtual.
  • Job description: holds the configuration, schedules jobs, allocates resources, and coordinates every backup and restore. It also doubles as a general-purpose backup proxy, so it can move data to and from repositories on its own.
  • Where it sits in the diagram: top-left, feeding the plug-in.
  • Mental model: the control tower. It decides what and when; it does not read VM disks.
Veeam Plug-in for KubeVirt — the translator
  • What it is: the integration layer between VBR and everything OpenShift Virtualization.
  • Job description: lets the backup server connect to an OpenShift Virtualization cluster and run data protection and disaster recovery tasks against its resources.
  • Where it sits: still on the Veeam side of the line, but it's the component that reaches down into the cluster (the green arrow going into the Veeam KubeVirt Proxy).
  • Mental model: a bilingual dispatcher. VBR speaks "jobs and repositories"; the cluster speaks "pods and PVCs". This is where the translation happens.
Veeam KubeVirt Proxy — the resident inside the cluster
  • What it is: an ephemeral container living in a pod in the protected cluster.
  • Job description: processes backup workloads when data moves to and from repositories.
  • Rules of engagement: exactly one proxy per protected cluster. If you have three clusters, you deploy three proxies and one VBR can connect to all of them.
  • Where it sits: left side of the OpenShift box, wired to KubeVirt (blue) and to the plug-in (green).
  • Mental model: the site foreman. It's the only permanent Veeam presence in your cluster, and it's the one that hires the workers below.
VKP Data Mover — the temp worker who does the actual lifting
  • What it is: a service in a pod that the proxy deploys temporarily for a job.
  • Job description: on backup, it pulls the data of the protected VM disks and ships it to the repository; on restore, it pulls from the repository and writes to the target.
  • Where it sits: center-right of the diagram, one per VM being processed (Data Mover 1 → VM1, Data Mover 2 → VM2), each attached to the VM's PVCs.
  • Mental model: contractors that show up for the shift and leave. This is the pod your platform team will see appear and disappear during the backup window — and the reason there's no agent inside the guest.
Backup Repository — where it all lands
  • What it is: the storage location where VBR keeps backups of your OpenShift Virtualization VMs.
  • Job description: be the destination. Nothing exotic here — it's the same repository concept you already use.
  • Where it sits: top-right, receiving green arrows straight from the data movers.
  • Mental model: the warehouse. Same warehouse as your vSphere and Hyper-V backups, which is exactly the point.
Reading the diagram as a timeline
If you follow the arrows in order, the picture becomes a sequence rather than a topology:
  1. VBR hands the job to the plug-in.
  2. The plug-in reaches the proxy inside the cluster.
  3. The proxy spins up one data mover per VM and points each at that VM's disks through KubeVirt.
  4. Each data mover streams straight to the repository.
  5. When the job ends, the data movers are gone; the proxy stays for next time.
Two of those steps run entirely inside OpenShift, near the storage. That's the design choice worth remembering: the backup server orchestrates, the cluster does the data path.
For the entire Veeam team who released this incredible Plug-In
9 comments
Great to see this plugin as I am sure it will be highly used.  Looking forward to testing this one.
eblack
  • Sep 14, 2026 2:13 PM UTC
I’m also excited about getting some time with this. Nice write up.
Geoff Burke
  • Sep 14, 2026 5:04 PM UTC
It is out now! I have installed and connected to OKD (upstream OpenShift). Migrated a VM from VMware to OpenShift, worked flawlessly. Keep in mind when migrating to OpenShift you need to have storage class that supports RWX access mode. In my lab I was using topolvm so had to quickly setup a small Ceph cluster with the rook operator.
eprieto
  • Sep 14, 2026 5:20 PM UTC
Hi Geoff, excellent !! Nice Home Lab!!
eprieto
  • Sep 14, 2026 5:22 PM UTC
Thanks, I think that this Plug-In do more easy the talk with my customers hehe
eprieto
  • Sep 14, 2026 5:24 PM UTC
Hi Chris, Let us know when you try it.
SCZEPANSKI
  • Sep 19, 2026 11:40 AM UTC
Truly a topic that is rarely explored.
Congratulations!
  • Oct 12, 2026 1:58 AM UTC
Veeam KubeVirt Protection – Multus NAD Support for Data Mover Pods
Hi everyone,
I'm evaluating Veeam KubeVirt Protection (VKP) for OpenShift Virtualization and would like to clarify whether there is support for attaching a secondary network interface to the temporary VKP Data Mover pods using Multus and a NetworkAttachmentDefinition (NAD).
In our environment, we would like to keep the management and control-plane communication on the standard OpenShift network, while routing the actual backup and restore data traffic through a dedicated VLAN and network interface, isolated from the cluster's pod network.
This would be similar to the approach available in Veritas NetBackup, where additional network attachments can be configured for Data Mover pods.
My questions are:
  1. Does the current version of Veeam KubeVirt Protection support attaching a Multus NAD to temporary VKP Data Mover pods?
  2. If this is not currently supported, is this capability planned for a future release? Is there an estimated timeframe?
  3. Is there any supported workaround to direct backup and restore data traffic through a dedicated network, without changing the management connectivity?
I understand that KubeVirt Protection is a relatively new solution, and this capability would be very valuable for enterprise environments where backup traffic isolation, network segmentation, and predictable data paths are important requirements.
Thanks in advance for any clarification or roadmap information.
  • Oct 12, 2026 2:19 AM UTC
Check this out! →
Â
