Replication Relationships not found with NetApp SnapMirror on with NFS volume
  • Nov 19, 2026 8:26 PM UTC
  • 47 views
Pybarra
There has probably some SnapMirror issues mentioned in the community hub in the past. NetApp has updated it KB article and Veeam also listed it in its documentation. I will show a couple of screenshots below and the links to the KB and Veeam user guide. The initial error appears in figure 1 below.
“Cannot find snapshot replication relationships”. In most cases it is related to a storage configuration. There could be other issues going on but, in this case, the steps in NetApp KB article solved the problem. I always recommend calling Veeam or NetApp support to analyze logs if needed.
Figure 1 Cannot find snapshot replication relationships
Although there is already a SnapMirror relationship established it will fail if these other items are not configured on the NetApp storage below. The NetApp KB article covers this in detail.
  1. NFS volume not mounted. This is standard for NetApp since secondary SnapMirror destinations are not mounted by default. VBR needs to see the volume and process the request.
  2. Export policy needs to have the VBR proxy IP/DNS address.
  3. NFS protocol licensed and enabled.
  4. NFS LIF (network) port.
  5. NFS services must be allowed on NFS LIF.
  6. Rescan NetApp storage in VBR.
In figure 2 below. The storage configurations were done and the job completed successfully.
Figure 2 - Job completed successfully
Veeam documentation link - NetApp ONTAP, Fujitsu ETERNUS HX/AX, Lenovo ThinkSystem DM/DG (Built-In Storage Systems)
NetApp KB link included in Veeam user guide above - Veeam ONTAP Plugin fails to replicate secondary snapshots source or target LUNs not found
matheusgiovanini
Great article! Thanks for sharing this troubleshooting guide.
Pybarra
  • Nov 20, 2026 12:48 AM UTC
Your very welcome, ​@matheusgiovanini 😀!
MatzeB
  • Nov 23, 2026 6:53 AM UTC
Very helpful - i can tell you i got asked this question 100 times in the last years. Especially there are some corner cases where replication works and the destination is found. But if you dont have access (export/IP etc) to the secondary - veeam couldn’t count the destination number of VMs (Important - number of VMs - not snapshots) and there for retention does not work.
Matze
Pybarra
  • Nov 23, 2026 3:30 PM UTC
Thanks, ​@MatzeB I appreciate your feedback. You have a lot of Veeam NetApp expertise😀.
