As-Build Report Veeam - Guide for an easy installation
Badge +5
Hi All,
I can share my As-Build Report Veeam guide for an easy installation and a good results 😁 !
Sources:
https://github.com/AsBuiltReport/AsBuiltReport.Veeam.VBR
PS> $env:PSModulePath
Attending result:
Configure report options for use with -Verbose option to Allows you to set the technical parameters of the report, such as the type of data collected:
Enjoy Veeam reports !
41 comments
Hi Christopher,
When this error appears, does the script abruptly terminate without generating the report or is it completely generated and it is just a warning message?
Have a nice day.
I’m using a Rental license on a Veeam Server. The license typ is Enterprise plus.
While running the report I got the following message:
“New-AsBuiltReport : Current license does not allow this operation”
Is there a way to get rid of these error?
Regards
Christopher
Which report were you trying to run and what switches?  That is odd as I use the same license type and never have this issue running the utility.
Userlevel 2
Hi Christopher,
Have a nice day.
Hello Jonathan,
the script will terminate and no report is generated.
Here you can see the output on the powershell console:
 <       As Built Report Configuration      >
Would you like to save the As Built Report configuration file? (y/n): n
Please wait while the Veeam VBR As Built Report is being generated.
WARNUNG: [ 14:11:19:480 ] [ Document ] - Please refer to the AsBuiltReport.Veeam.VBR github website for more detailed information about this project.
WARNUNG: [ 14:11:19:496 ] [ Document ] - Do not forget to update your report configuration file after each new version release.
WARNUNG: [ 14:11:19:496 ] [ Document ] - Documentation: https://github.com/AsBuiltReport/AsBuiltReport.Veeam.VBR
WARNUNG: [ 14:11:19:496 ] [ Document ] - Issues or bug reporting: https://github.com/AsBuiltReport/AsBuiltReport.Veeam.VBR/issues
WARNUNG: [ 14:11:19:558 ] [ Document ] - AsBuiltReport.Veeam.VBR 0.8.4 is currently installed.
WARNUNG: [ 14:12:04:433 ] [ Document ] - Malware Detection Exclusions Section: Das Argument kann nicht an den Parameter "Rows" gebunden werden, da es sich um eine leere Auflistung handelt.
WARNUNG: [ 14:12:04:449 ] [ Document ] - VM Exclusions Section: Das Argument kann nicht an den Parameter "Rows" gebunden werden, da es sich um eine leere Auflistung handelt.
WARNUNG: [ 14:12:40:402 ] [ Document ] - Inventory Summary Section: Current license does not allow this operation
In Zeile:1 Zeichen:1
+ New-AsBuiltReport -Report Veeam.VBR -Target veeam-backup -Username '. ...
    + CategoryInfo          : NotSpecified: (:) [Write-Error], WriteErrorException
    + FullyQualifiedErrorId : Microsoft.PowerShell.Commands.WriteErrorException,New-AsBuiltReport
Regards
Christopher
Userlevel 2
Regards
Christopher
Hi Chris,
here you can see the report command:
New-AsBuiltReport -Report Veeam.VBR -Target veeam-backup -Username '.\xxxxxx' -Password 'xxxxxxxx' -Format Html,Word -OutputFolderPath 'G:\Report' -Timestamp
It’s good to here that it’s running in your environment.
Regards
Christopher
Your license has not expired, has it?  I would not think so but wonder if it does a check when running the report or something?  I have not studied it in depth but wondered.  Hopefully @jcolonfzenpr can answer.
Hi Christopher,
Have a nice day.
Hello Jonathan,
Regards
Christopher
This two warning messages will be fixed in the next release
https://github.com/AsBuiltReport/AsBuiltReport.Veeam.VBR/issues/145
The ErrorException is obviously a bug! I will be analyzing the code and let you know the result.
Regards
Yeah, it would be good to validate that the license is not expired.
Thanks, was just a thought and maybe not relevant but I check everything.  😁
Can you run the following commands so I can determine which cmdlet is causing the error?
# Connect to VBR server
Connect-VBRServer -Server veeam-backup.domain.local -User "username" -Password "password"
Get-VBRNASServer
Get-VBRUnstructuredServer
Get-VBRProtectionGroup
Userlevel 2
Get-VBRNASServer
Hi Jonathan,
here is the actual output.
PS C:\Users\Administrator> Connect-VBRServer -Server veeam-backup -User "xxx" -Password "xxx"
PS C:\Users\Administrator> Get-VBRNASServer
WARNUNG: This cmdlet is obsolete, use Get-VBRUnstructuredServer instead.
PS C:\Users\Administrator> Get-VBRUnstructuredServer
PS C:\Users\Administrator> Get-VBRProtectionGroup
Get-VBRProtectionGroup : Current license does not allow this operation
+ Get-VBRProtectionGroup
    + CategoryInfo          : NotSpecified: (:) [Get-VBRProtectionGroup], LicenseException
    + FullyQualifiedErrorId : System.ComponentModel.LicenseException,Veeam.Backup.PowerShell.Cmdlets.GetVBRProtectionGroup
Userlevel 2
Hi Chris,
the license will expire in 6 month. ;-)
Regards
Christopher
Thanks.  So it seems the VBR protection group is the one causing the license message. I am sure @jcolonfzenpr will sort you out.
Get-VBRNASServer
Hi Jonathan,
Thank you for helping us with finding the problematic powershell cmdlet.
Until I can find a solution, you can generate a ReportConfig so that the entire inventory section can be disabled.
New-AsBuiltReportConfig -Report Veeam.VBR -FolderPath <User specified folder> -Filename <Optional>
https://github.com/AsBuiltReport/AsBuiltReport.Veeam.VBR?tab=readme-ov-file#pencil2-configuration
After generating the ReportConfig json file open it and set all values in the Inventory section to 0.
Then run the report with the -ReportConfigFilePath <Path> option.
New-AsBuiltReport -Report Veeam.VBR -Target veeam-backup -Username '.\xxxxxx' -Password 'xxxxxxxx' -Format Html,Word -OutputFolderPath 'G:\Report' -Timestamp -ReportConfigFilePath <Json Path>
Ironically the Get-VBRProtectionGroup command is not supposed to cause any issue with the report because I am running it inside a try/catch statement but like everything in IT... Murphy's law is always after us.
Have a good day!
I will keep this in mind if I run into this issue but have not so far.
Get-VBRNASServer
Hi Jonathan,
Just to let you know that in version 0.8.5 the bug has been fixed and added many many new features!
## [0.8.5] - 2024-03-15
### Added
- Added Option => History section
- Improved Role & Users section
  - Added Global MFA settings
  - Added Auto logoff on inactivity setting
  - Added Four-eye Authorization setting
  - Added HealthCheck conditions
- Added Backup Time Duration table to the Jobs Summary. Close [#144](https://github.com/AsBuiltReport/AsBuiltReport.Veeam.VBR/issues/144)
- Added Restore point reporting. Close [#143](https://github.com/AsBuiltReport/AsBuiltReport.Veeam.VBR/issues/143)
- Added Automatically disable Windows Firewall option to the SureBackup verification section
### Changed
- Removed Graphviz install check code. (No need to manually install Graphviz)
- Code Cleanup
- Increased Veeam.Diagrammer module requirement to v0.5.9
### Fixed
- Improved error handling on the Diagram section.
- Fixed issue with the Veeam.Diagrammer module.
- Resolved issue that prevented SureBackup Virtual Lab information to be collected. Fix [#142](https://github.com/AsBuiltReport/AsBuiltReport.Veeam.VBR/issues/142)
- Resolved issue in the Malware Global Exclusions section. Fix [#145](https://github.com/AsBuiltReport/AsBuiltReport.Veeam.VBR/issues/145)
- Resolved an issue related to Protection Group licensing. Fix [#146](https://github.com/AsBuiltReport/AsBuiltReport.Veeam.VBR/issues/146)
Very nice updates and additions.  Time to test this new release.  😎
