Hi All,
I can share my As-Build Report Veeam guide for an easy installation and a good results 😁 !
Sources:
https://github.com/AsBuiltReport/AsBuiltReport.Veeam.VBR
PS> $env:PSModulePath
Attending result:
Configure report options for use with -Verbose option to Allows you to set the technical parameters of the report, such as the type of data collected:
Enjoy Veeam reports !
