I am preparinf for my VMCE_v12 exam and i am seeking best exam preparation resource. Are there any practice test i can access to prepare for my exam?
Best answer by MicoolPaul
View originalI am preparinf for my VMCE_v12 exam and i am seeking best exam preparation resource. Are there any practice test i can access to prepare for my exam?
View originalHi, the best exam prep for the VMCE is trying the different features in a lab/your environment, and reading the Veeam documentation. None of the questions are designed to trick you and are more focused on your understanding of concepts than explicit details.
I believe the Veeam partner portal has some mock exams if you’re a partner. I’d also suggest trying the Veeam hands on labs 🙂
Hi
https://rasmushaslund.com/vmce-practice-exam/
Also the blog of Hammond Rhys has a lot of info.
https://rhyshammond.com/vmce-material/vmce-2021-practice-exam-pool/
When you have access to the Veeam Propartner Portal, there is a test-quiz available.
ho
if you want check Veeam Hands-On-Labs
check this Back to Veeam University! | Veeam Community Resource Hub
Yes, its true. Me too will start practice coming soon for VMCE :)
Aside from the suggestions already offered, there is a VMCE page here on the Community Hub with study suggestions & practice questions as well.
