VEEAM is up and running in my environment - any advice on how to speed up my backups?
  • Aug 22, 2023 3:42 PM UTC
  • 39 comments
  • 7437 views
Show first post
39 comments
  • Aug 24, 2023 6:31 AM UTC
"dumb question : anyone ever seen faster speeds?"
Yes..up to 3GB in my environment. Doesn't happen often. I use backup from storage snapshot, similar to DirectSAN, except the backup is taken from a snap of my Nimble Volume. But most of the time my speeds are only around 600MB to about 1GB.
Glad things are working well.
Direct SAN is enabled and rocking and rolling
we are reading and writing at 1gbps or more and it’s glorious
if so, how?
thanks for all of the help and advice guys
There was a ‘beat the Gostev’ challenge that Veeam ran, which saw a couple of submissions of over 100GBps. The winner was 147.7GBps, so Veeam does scale VERY well.
Make sure you’ve got Multipath IO enabled so that you can write to your Nimble via multiple channels. Are your data interfaces shared for access to Nimble and your production storage?
A diagram of your topology would be a good place to identify potential bottlenecks. There’ll always be a bottleneck but it’s got to be fast enough to meet your needs. I just did a deployment that was seeing 4-5GBps throughput per site, it was with a couple of HPE Apollos per site, with multiple RAID Controllers and RAID volumes per HPE Apollo, with 40GbE and 32Gbps Fibre Channel to read from production. The bottleneck is source! 😁
  • Aug 24, 2023 12:46 PM UTC
i hit 3GB at peak, I’ll hit 2GB often, and 1GB is common, however, depending on how much data is running per job, and concurrency i see as low as 500MB.
As stated WAN accelerators only help for shipping data offsite, and if you have a 10Gbps connection YMMV. I don’t use one and send a bunch of data to other locations without issue.
clownyboots178
  • Aug 24, 2023 2:08 PM UTC
I dont know what happened exactly, but I went from 1gbps read and 950mbps write speeds to 80mbps write or even lowere
any idea why that might have happened?
My job also says “DirectSAN is not available failing over” but I have failover turned off
Are there any recent changes to your network or any failures on switches or something?  You can also check the logs to get more details - C:\ProgramData\Veeam\Backup
Hi, I notice your screenshot says “Using backup proxy VMware Backup Proxy”, this is the default proxy deployed when you install Veeam. Is this intentional that you’re using this server as a proxy? Or do you have Veeam as a virtual machine for example, and then a physical server as your proxy & repository?
clownyboots178
  • Aug 24, 2023 2:35 PM UTC
This is intentional, we have a dedicated Dell box that has way more horsepower than it needs and we did that so it could be the proxy and handle anything we throw at it
No network changes as this happened every night this week between the same time frame with all other jobs
what should I look for in the logs?
How is the storage you are backing up from connected to the environment?  iSCSI or FC?  Might want to look there since it failed over to Network mode.  There is a connection to the storage preventing the Direct SAN access.
So this Dell box is the VBR server + Proxy correct?
  • Aug 24, 2023 2:44 PM UTC
Hi @clownyboots178
do proxies and vbr have access to proxies\datastores?
Have you set proxy-side direct storage access mode?
Backup Proxies -> VMWare Backup Proxy -> Transport Mode
and in the job check this.
ATTENTION.
Only the VM disks "Thick Provision Lazy Zeroed" and "ThickProvision Eager Zeroed" can be used in Direct SAN mode.
check this:
Direct SAN Access - User Guide for VMware vSphere (veeam.com)
clownyboots178
  • Aug 24, 2023 3:06 PM UTC
Hi @clownyboots178
ATTENTION.
check this:
both of those options have been checked for some time, and we found out that only THICK drives will work with DirectSAN, we are all THIN, so we are not actually using it I suppose, but since we have the LUNs connected to this machine, our speeds were amazing and the indicate “(san)” within the job
something has to be happening on the network or with the server being that this happens every day on every job - we have a GPO auto logging off everyone, could that cause an issue?
I would not think an auto logoff GPO would factor in to this. As noted you are using Thin provisioning and based on the previous post is part of the issue.  Maybe this requires a support case to further investigate.
clownyboots178
  • Aug 24, 2023 3:46 PM UTC
I am talking with someone now about it all
You guys have been a terrific help and always are here to help me out with things
thanks for all of the advice, things are moving much better now
thanks again guys
  • Aug 24, 2023 7:02 PM UTC
It’s trying to use DirectSAN, failing, then failing over to VMware Backup Proxy.
Now, depending on how “VMware Backup Proxy” is configured, that is your issue.
For me, “VMware Backup Proxy” in this case would be a VM, if it was on the same HOST as the VM being backed up, it would use [HotAdd] and be quite fast. It essentualy mounts the volume then spits it out the 10Gb  port in the VMware host.
This is why multiple VM proxies (1 per host are recomended) are needed to go this route. If it isn’t on the same host it uses NBD.
It will also be using the VMware Management ports, with overhead in this case.
If you have 1 Gb management ports, it’s slow….. that speed is within the 1Gb range. 1Gbps = roughly 125MB (Theoretical max)
10Gb = 1200MB so you will see around 1GB in Veeam.
Check your transport modes, make sure your proxy that you are using and VMware management ports are 10Gb networking.
What I do is thin provision everything on the SAN itself to save space, but create my VM’s thick provisioned. It’s a double bonus that they don’t expand and blow up the datastore too.
