Script to perform Failover and undo failover using Veeam replica
  • 23 September 2021
  • 42 views
We wish to run the replica on a different IP periodically to extract data from the VM.  Hence time and again I perform failover to replica using the RE IP options within Veeam and then undo the failover.
Just checking if anyone has anyone automated failover and undo failover for a Veeam replica using Powershell.
icon
Best answer by Chris.Arceneaux 23 September 2021, 14:47
Badge +5
It’s a few years old, but perhaps this will work for you?
https://github.com/VeeamHub/powershell/tree/master/BR-UpdateReplicaIP
VeeamHub is a central repository of all community scripts related to Veeam. I highly recommend you give it a look through as there is a LOT of great content there.
