This is a very simple calculator that uses backup size from the Veeam official calculator, the tape capacity, and the number/ retention amount required. Based on this information, it will tell you how many tapes you will need. http://tape.skitchlab.com
Awesome...I don’t use tapes often, but when I do, this will be super helpful! Thanks for the share!
