Powershell COM Help
  • Apr 26, 2024 2:37 PM UTC
  • 155 views
ratkinsonuk
Forum|alt.badge.img+2
Forgive me, as this isn’t strictly a Veeam topic, but I’m pulling my hair out.
I’m trying to enhance a Windows Update Powershell script. The current script occasionally hangs when we invoke a COM CreateUpdateSearcher() method.
$updateSession = new-object -com "Microsoft.Update.Session"
$Criteria = "IsInstalled=0"
$updates = $updateSession.CreateupdateSearcher().Search($criteria).Updates
This runs synchronously, so I can’t trap the hang. Instead, I want to use the BeginSearch() method that runs asynch (https://learn.microsoft.com/en-us/windows/win32/api/wuapi/nf-wuapi-iupdatesearcher-beginsearch).
My problem is it requires an ‘IUnknown ISearchCompletedCallback’ object to be passed as one of the parameters. I don’t need this to be invoked, so it can be an empty object, but I can’t work out how to create an empty IUnknown object.
$UpdateSession = New-Object -ComObject "Microsoft.Update.Session"
$objSearcher = $UpdateSession.CreateUpdateSearcher()
$objSearch = $objSearcher.BeginSearch('IsInstalled=0',??,$null)
Can anyone help please!
Rob.
Chris.Arceneaux
Hi Rob,
Have you tried using PowerShell’s built-in job functionality? This would force the process to the background and then you can monitor the job.
https://learn.microsoft.com/en-us/powershell/module/microsoft.powershell.core/start-job?view=powershell-5.1
Hope this helps!
Chris
ratkinsonuk
  • Apr 26, 2024 3:01 PM UTC
That’s my Plan-B Chris if I can’t work out the New-Object syntax, but I hate to be beaten into submission 😋
Rob.
