Hey y’all, doing a bit of testing with VB365 v8 and documented my way through getting PostgreSQL setup on a ubuntu 22.04 server for this purpose and it seems to be working very well. Here’s the link if you think it will help you out! https://www.koolaid.info/postgresql-on-ubuntu-2022-4-installation-configuration-for-veeam-purposes/
Great post Jim! I want to write a similar article, but using a docker container for postgres instead of a straight install.
I’ve been thinking along the same lines but baby steps!
Man put it in a Kube cluster :) docker on its own is very lonely :)
you can create a single node k3s then use helm for postgresql, not difficult. Then you can back it up with Kasten too!!
Enter your username or e-mail address. We'll send you an e-mail with instructions to reset your password.
