Hi Community,
I want to post a question on the R&D Forum, but I see no option to do it, I Also tried to send a message, but the system doesn’t allow me to do it probably because I’m not an active member.
Does anyone knows how to fix it?
Hi Community,
You need to contact them on the Forums to ask this and get it addressed. There is technically no “Questions” on the forum but just posts which can be questions.
If you don’t have permission there should be a contact link somewhere to get help to fix your account.
Andre, when you go to a sub forum (like Veeam Backup & Replication) don't you see a create new topic button like this?
Hi Weslay, that option is not available on my profile.
I tried to send a message, but the system doesn’t allow me to send.
Hi Weslay, I found it, is was down below. thank you!!!!
I meant to use this option at the bottom of the page.
Hi Chris, Weslay was right, his reply soved my needs. tahnk you anyway. :-)
Sounds good. Glad you were able to get things resolved.
