Is there any way to report (powershell script etc.) on Nutanix AHV repository hosted content (via Hyper-V) except for using the Veeam ONE “Protected VMs) report. Information required, Succesful backup sessions: Job anme, start & stop times, Durations, avg speed, total, processed, data read, transferred, dedup, compression, result.
If you don't want to use VONE them check this post in the forum which references PowerShell and also gives a tip about speed - https://forums.veeam.com/powershell-f26/how-to-get-backup-session-report-by-powershell-t81284.html
