[Quicktip] Take care when using PowerShell cmdlet Remove-VBRSureBackupJob!
  • 10 December 2021
  • 7 comments
  • 71 views
Badge +13
Yesterday I found a strange behavior in the Veeam PowerShell cmdlet Remove-VBRSureBackupJob. What happens: when you use this cmdlet to remove a certain SureBackup-Job using the parameter -Job, ALL SureBackup-Jobs will be deleted!. In my environment version 11.0.0.837 P20210525 was used. It seems the be a bug.
[update] In the meantime Veeam confirmed that it is a bug. Also in v11a!
https://forums.veeam.com/powershell-f26/remove-vbrsurebackupjob-deletes-all-surebackup-jobs-t78189.html
So when you test or plan to using scripted SureBackups, do not use Remove-VBRSureBackupJob currently!
Badge +7
Thanks for the heads up!
Badge +13
You are welcome! I hope you did not run into the issue!
Badge +7
Luckily, we don’t have any SureBackup jobs to delete at the moment so all good at the moment.
Badge +13
Definitely not a funny bug.
Thanks for sharing.
Ouch, did not know this! Thanks for sharing.
Badge +13
Veeam seems to be surprised too :joy:
