How to get a restore job id for the VM using PowerShell command?
  • May 28, 2021
  • 326 views
We are not getting restore job Id while running the below PowerShell command in Veeam 11, but for versions below 11, we are getting the restore job id.
I checked the Veeam11 commands document but couldn’t find anything helpful regarding VM restore job id.
Let us know if there is any particular command to fetch the job id.
Running command using Veeam11:
$latest_backup_copy = Get-VBRBackup -Name 'backup_job_0'| Get-VBRRestorePoint -Name 'oracle_smallest' | Sort-Object -Property CreationTime -Descending | Select -First 1 ;;  Start-VBRRestoreVM -RestorePoint    $latest_backup_copy -ToOriginalLocation             -StoragePolicyAction Default -PowerUp:$True             -RunAsync
Restore Type       VM Name              State      Start Time             End Time               Description
RestoreVm          oracle_smallest      Starting   5/28/2021 12:17:24 PM  1/1/1900 12:00:00 AM
Running  same command using Veeam 10a:
Not sharing the whole output just a snippet with job id
$latest_backup_copy = Get-VBRBackup -Name 'backup_job_0'| Get-VBRRestorePoint -Name 'oracle_smallest' | Sort-Object –Property CreationTime –Descending | Select -First 1 ;;  Start-VBRRestoreVM -RestorePoint   $latest_backup_copy -ToOriginalLocation             -StoragePolicyAction Default -PowerUp:$True             -RunAsync "
IsCompleted          : False
IsWorking            : False
IsStarting           : True
IsPostprocessing     : False
JobId                : 1c7b60ec-4e8f-43ea-8d69-bb0cb8e1ae44
Result               : None
State                : Starting
EndTime              : 1/1/1900 12:00:00 AM
EndTimeUTC           : 1/1/1900 12:00:00 AM
CreationTime         : 2/10/2021 12:17:01 PM
AuxData              : <AuxData><SessionStarterInfo Version="1" UserName="Administrator" UserDomainName="."
                       RunManually="True" LoginType="4" LoginName="Administrator" /></AuxData>
IsLowerAgentPriority : True
LogName              : oracle_smallest
LogsSubFolder        : oracle_smallest
Logger               : Veeam.Backup.Core.XmlLogger
Tracer               : Veeam.Backup.Core.CSessionLogTracer
Best answer by JMeixner
Another possibility is
Start-VBRRestoreVM -RestorePoint    $latest_backup_copy -ToOriginalLocation             -StoragePolicyAction Default -PowerUp:$True -RunAsync  | Select -property JobId
Forum|alt.badge.img+18
  • May 28, 2021
please try the following:
$result = Start-VBRRestoreVM -RestorePoint    $latest_backup_copy -ToOriginalLocation             -StoragePolicyAction Default -PowerUp:$True             -RunAsync
$result.JobId
This gives the JobId to you...
  • May 28, 2021
  • May 28, 2021
Hi Joe,
Thanks for the quick response and it is working.
  • May 28, 2021
You are welcome :sunglasses:
Fine that it is working….
