Lab View: How to Transition from Reactive to Proactive (Step-by-Step) with Veeam - Part 2
  • April 13, 2026
  • 79 views
kciolek
In Part 1, we talked about the difference between reactive and proactive Veeam operations.
But knowing the difference is the easy part.
The real question is:
How do you actually make the transition—without overhauling everything at once?
Because most environments can’t just stop and rebuild.
They have to evolve.
This is how you do it—step by step, without creating more chaos in the process.
Step 1: Get Visibility (You Can’t Fix What You Can’t See)
Before you change anything, you need a clear picture of where you are.
Start with:
  • Job success vs warning vs failure rates
  • Backup job durations (are they increasing?)
  • Repository capacity and growth rate
  • Restore success history (if any exists)
The goal:
Understand your baseline.
Not what you think is happening—what’s actually happening.
Proactive operations start with awareness.
Step 2: Clean Up the Noise
Most reactive environments have one thing in common:
Too many alerts. Too many warnings. Too much noise.
Do this next:
  • Review all current warnings
  • Fix what matters
  • Document or suppress what doesn’t
Why this matters:
If everything looks like a problem, you won’t know when something actually is.
You can’t be proactive if you’re constantly distracted.
Step 3: Establish a Daily Health Routine
This is where the shift really begins.
Not a full audit. Not hours of work.
Just a consistent, focused check.
Your daily 5–10 minute review:
  • Job results (especially warnings)
  • Any failed sessions
  • Capacity thresholds
  • Unusual performance changes
The key:
Consistency over complexity.
You’re building awareness—not adding overhead.
Step 4: Introduce Basic Monitoring & Alerting Discipline
Now that noise is reduced, your alerts can actually mean something.
Focus your alerts on:
  • Job failures
  • Repeated warnings
  • Capacity thresholds (before critical)
  • Infrastructure issues (proxy/repository stress)
What to avoid:
  • Alerting on everything
  • Ignoring alerts altogether
Good alerting doesn’t tell you everything—it tells you what matters.
Step 5: Start Tracking Trends (Not Just Events)
Reactive teams respond to events.
Proactive teams watch trends.
What to track weekly:
  • Job duration changes
  • Backup window utilization
  • Repository growth
  • Bottleneck patterns
What you’ll start seeing:
  • Slowdowns before they become problems
  • Capacity issues before they’re urgent
  • Patterns you can act on early
This is where you move from reacting → anticipating.
Step 6: Schedule Your First Real Restore Test
This is the turning point.
Most environments delay this step.
Don’t.
Start simple:
  • Restore a single VM
  • Restore a file
  • Validate application recovery (if applicable)
Document:
  • Time to recover
  • Issues encountered
  • Gaps in process
You’re not just testing data—you’re testing your ability to respond.
Step 7: Standardize What You Can
Once you understand your environment, you’ll start noticing inconsistencies.
Clean them up:
  • Align job configurations
  • Standardize naming conventions
  • Reduce unnecessary exceptions
Why it matters:
  • Easier troubleshooting
  • Predictable behavior
  • Less operational friction
Standardization is what makes proactive operations sustainable.
Step 8: Add Capacity Awareness
At this point, you should already have visibility into growth.
Now you act on it.
Do this:
  • Estimate when storage will fill up
  • Adjust retention if needed
  • Plan expansion before it’s urgent
The shift:
“We’re out of space”
To:
“We’ll need more space next quarter.”
Step 9: Document a Basic Runbook
You don’t need a massive document.
Start with the essentials:
Include:
  • How to restore a VM
  • How to restore files
  • Who to contact for escalation
  • Where backups are located
Why this matters:
  • Reduces dependency on memory
  • Speeds up response time
  • Enables others to step in if needed
If it only exists in your head, it’s not operationally ready.
Step 10: Repeat, Refine, Improve
This isn’t a one-time project.
It’s a shift in how you operate.
Over time, you’ll:
  • Improve monitoring
  • Expand testing
  • Refine processes
  • Increase confidence
And eventually…
You’ll notice something:
Things stop breaking unexpectedly.
What This Looks Like in Practice
You’ll go from:
  • Reacting to failures
  • Guessing recovery times
  • Scrambling for capacity
To:
  • Predicting issues early
  • Knowing your recovery capabilities
  • Planning ahead with confidence
Final Thought
You don’t need to transform everything overnight.
You just need to start moving in the right direction.
Proactive operations aren’t built in one big change.
They’re built through small, consistent improvements.
Start with visibility.
Reduce the noise.
Test your recovery.
And keep going.
Because the goal isn’t perfection.
It’s predictability.
And that’s what turns backup environments into reliable platforms.
In the next article we’ll look at “What proactive Veeam operations look like at Scale”
matheusgiovanini
Excellent post!
The biggest challenge I still see is that many environments are technically “protected”, but not truly validated.
Thanks for sharing!
kciolek
  • April 13, 2026
Excellent post!
Thanks for sharing!
thank you! i appreciate that! yes - i hear from so many customers and the don’t validate that backup works. It’s so simple with Veeam to run a quick restore or setup a SureBackup job.
