Hi All,
I wonder, what kind of tools are you using for your day-to-day automation tasks?
My top / most used list:
- Chocolatey
- Boxstarter
- PowerShell
- Ansible
- Bash
Hi All,
Pretty much just PowerShell for me, but I’m a bit of an automation newbie, so I’m open to options! Whatever tool works best for the task at hand.
I wonder if you can classify Chocolatey as automation tool …. nobody said apt, yum or zypper :D Though I am using chocolatey, too ;-)
I use Veeam Backup & Replication - It automagically starts jobs and is also able to trigger my Powershell scripts 🤣
Joking apart, I’m using Powershell and simple batch scripts and on Linux the good old bash. I don’t know if we can count AWS Cloudformation to it, but it also helps to setup testing environments.
Whaha, yes VBR does some stuff automagically as well 🤣
CloudFormation is a method of deploying AWS environments, Infrastructure as Code. I would say YES that counts automation as well!
Honestly most of what I use these days is powershell by way of VS Code. I also use the various swagger docs for Veeam products as well to help guide my calls and test capabilities. Enough that I keep them all as a pinned tweet!
https://twitter.com/k00laidIT/status/1364586142025322499?s=20&t=vDeDsTvPY_G3ZfsOiPBcCA
The list has gotten longer…
PowerShell, Ansible, Terraform, Bash, GitHub Actions, Gitlab, Circle CI, ArgoCD
And getting back into Python after a few years.
Enter your username or e-mail address. We'll send you an e-mail with instructions to reset your password.
